1010
toolbar in IE8, webschedule?
We are using webSchedule 9.2, and on the AppointmentAdd.aspx page it uses a webToolBar.  in IE8 it does not render properly - the buttons are misaligned - save, recurrence etc.
I am posting here under the toolbar because it appears the toolbar is the culprit!  IT is rendering a table using <colgroup> and <col>.  When creating an appointment, the delete button is hidden.  THe toolbar seems to be trying to do this by setting the <col> to display:hiden visibility:none.  However IE8 is ignoring these styles rules!
After much googling I found that if I edit the AppointmentAdd.aspx and change the DOCTYPE from
!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"
to
!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"
it works.
It's strange my googling has revealed that in some cases using TABLE-LAYOUT:FIXED solves the problem, and that is actually on the ig:Toolbar tag:
<igtbar:UltraWebToolbar id="UltraWebToolbar2" style="TABLE-LAYOUT: fixed" runat="server" CssClass="Fonts" Width="100%" ImageDirectory=" " ItemWidthDefault=" " tabIndex="0" Section508Compliant="True">
and the HTML 4.0 doctype line is also in the code, but commented out.  Was IE8 testing not completed before this was shipped ROFL ????
I know we are back a version or two, on the initial release of 9.2, is this fixed in 10.1?
