I have a column in my grid which displays a button. For some reason the button displays in the column but with additional padding that I can't figure out how to remove. I also use DataGrid in other forms and I don't get this spacing problem. Here is the xaml for the column
<igGrid:TemplateColumn Key="*" Width="32"> <igGrid:TemplateColumn.ItemTemplate> <DataTemplate> <Grid Width="32"> <Button Click="Button_Click" Width="32" ToolTipService.ToolTip="Click to rollback" Padding="0" Visibility="{Binding Path=Customized, Converter={StaticResource rollbackVisibilityValueConverter}}" Style="{StaticResource rollbackImageContent}"> </Button> </Grid> </DataTemplate> </igGrid:TemplateColumn.ItemTemplate> </igGrid:TemplateColumn>
The button displays an image, and its width is 32. In a regular datagird, the button fills the entire column perfectly when I set its width to 32. In the XamWebGrid I have to make the width 42 because there appears to be a bunch of spacing/padding around the button.
Any help would be greatly appreciated.
So, all you need to do is remove the padding from the CellControl, which you can do via a style:
<ig:TemplateColumn.CellStyle>
<Style TargetType="igGrid:CellControl">
<Setter Property="Padding" Value="0"/>
</Style>
</ig:TemplateColumn.CellStyle>
Hope this helps,
-SteveZ
Thanks, that worked perfectly.
