I need to do two different things when a row is clicked vs double clicked. When clicked, I show a detail record, when double clicked, I pop it up to a new window. When I double click it shouldn't register a click event, but it does, so it both pops up the detail record + shows it in the page (which I don't want). Is this a bug and if so, is there a workaround?
thanks,
greg
That is a reasonable workaround. I've gone ahead and implemented it and it works, thank you.
Hi Greg ,
So, as you probably know, there isn't a click, let alone a doubleClick event on framework elements in SL. Thus, we've had to create our own. We raise the click event on mouse up, and the double click if mouse down fires twice within a certain period time, around 400 ms.
Since, we don't want to delay the click for 400 ms, we can't really distinguish between the 2, thus they both fire.
However, if you're willing to do so, then it's completely possible to handle this from your end, by using a DispatcherTimer.
timer.Interval = TimeSpan.FromMilliseconds(400);
timer.Tick += new EventHandler((sender, args) =>
// Add your Single Click code here:
timer.Stop();
void DataGrid1_CellDoubleClicked(object sender, CellClickedEventArgs e)
// Add your DoubleClick logic here.
void DataGrid1_CellClicked(object sender, CellClickedEventArgs e)
timer.Start();
Hope this helps,
-SteveZ
