We are having a problem with the htmlviewer and viewing an html page in IE. Once you have set focus to the web page (any web page) inside the viewer and click outside of the viewer, the contents of the viewer disappear. You need to scroll for it to return.
This does not happen in firefox, happens in ie7, ie8 and in compatibility mode. This does not happen when loading a pdf (using adobe reader) within the html viewer. I have 2 silverlight apps that use the viewer and it happens in both.
Any thoughts?
Lisa.
That was it.
Thanks so much!
Do you have the windowless parameter (http://msdn.microsoft.com/en-us/library/cc838156(VS.95).aspx) set to true?
The issue you are describing could be caused because the windowless parameter is not set.
Regards
