How can I bind the XamWebChart to a SeriesCollection. I'm getting data from a service, in Xml format, containing the values and styles for few series' with several datapoints.
I created SeriesCollection in my ViewModel. Now how should I bind my view to make it use the SeriesCollection to draw graphs.
Hi Graham,
Please help me with rendering part.
I have used the code as is, it's not rendering anything on the screen.
I am referring to the post made by:
[Infragistics] Graham Murray on 07-26-2010 5:31 PM
Is there a slightly easier way to achieve databinding rather than use what Graham has suggested?
Thank you for your post. I have been looking into it, but since in the thread there are a coouple of samples and links to other threads with samples, could pelase send me the one that you have issues with.
Hello Graham,
I have been trying to use your example with the latest version of Infragistics Wpf release. However in the function GetAxes, you have code such as this:
xAxis = (series as AnchoredCategorySeries).XAxis;But there is no property called XAxis defined anymore. It seems that they have removed this property. How do I modify the code to get this example to work with the new version of infragistics 2012 version.
Where are you running into the overhead? Do you have a profile? You may be able to tweak that method a bit to avoid the issue. There should be a bit of overhead when the custom type is generated, but as long as most of the dynamic types look the same it should be hitting the dictionary for each subsequent type that needs to be created.
Also, xamGrid probably supports binding against dictionaries, I would assume, is there a reason you aren't using that approach?
I'm not too familar with the xamGrid's backlog. I'd recommend makign a feature request, or possibly emailing productmanager@infragistics.com to inquire further.
-Graham
