I am getting a NULL reference with the following line for Firefox 3.6.2
int lActiveRow = UltraWebGridAdminReport.DisplayLayout.ActiveRow.Index;
It occurs with an ASP.NET server control button embedded into a Template column. The idea is to determine what row is for the button that is clicked.
I did not get this error with previous versions of Firefox and it doesn't occur in IE.
Is there a patch that needs to be downloaded?
Hello Scallejo,
Are you still seeing this issue? If so, let me know the version of the UltraWebGrid assembly in your application so I may do some testing.
Let me know if you have any questions with this matter.
Alan
