I am working on The XamWebMap control to render a set of big shapefiles. I would like to optimize my application so i could download the shapefiles in ziped format and put it in the Isolated storage, and to re use the same file over the life of the application. However the Shapefile reader only takes URI. Is there a way i could make it read from the Isolated storage? Are there any other optimization techniques i could use to avoid downloading of the big shapefiles?
Many Thanks
Unless I'm mistaken, the purpose of Isolated Storage Files is that you can't read them from another application. Its supposed to keep low trust apps from reading each others data. If you give high enough trust to an app, you may just be able to read the data off the file system though. But I'm pretty sure you aren't supposed to use the isolated storage system this way.
If you need global access to files from a silverlight application on a machine, you might either need to talk to a local web service that can give you the files, or make the app full trust and get them off the file system in some manner (COM?)
-Graham
If the data mapping isnt working, then it probably can't find the dbf file. Could you share a sample and I can help point out the issue?
The dbf file that it searches for uses a hard coded string in the above sample. Fix that so that it trims the shp and adds a dbf to whatever file name is presented, and it should resolve the issue.
Hi... This post solved my problem..
But I have one more problem.. i.e How can i read existing Isolated Storage Files in other silverlight application.
My requirement is. Like i have One Application which is used to Create a Isolated Storage and Copy files into it and having one more Application which is used to Read the copied files..
Here I am Getting problem to Read Existing Files from Isolated Storage. Its Creating another Isolated Storage and reading files from this new isolated storage..
Please Solve it asap...
Thank u..
Hi All,
I am able to use the Isolated storage through the above code. But data mapping for the reader is not giving color code if i map to any one of my fields in the shape file. Can any one help me out in this issue.
Thanks in Advance,
Pavan
