I want display only a certain area on a map. I tried using WindowRect WindowZoom and WindowScale.
Could any one gives me an example?
thanks in advance
http://community.infragistics.com/forums/p/37528/222726.aspx#222726
I am using SQL Server 2008 spatial to map US Counties. I tried using your code to determine outer bounds of the elements, but all of the elements have the same WorldRect value. The value is the same as the WorldRect value for the map. Any idea why this is happening?
I am using SQL Server 2008 spatial to map PA Counties.
Thanks!
Jason
Imported will get called multiple times indicating the status of the mapfile import, so you could display a status bar. It will have an action of
MapLayerImportAction.End
when it is finished importing.
I also found Imported got called multiple times.
Would you please explain why Imported can often get called multiple times?
Imported can often get called multiple times, if you are debugging, its best to wrap your logic in a conditional that the element count is greater than 0.
