I am looking to read an excel file into the workbook.
the issue is that the columns in my excel sheet are not certain or pre-defined.
They may vary and I don't want to put any column schema restriction as such.
In the samples you have a observable collection having some pre-defined data members.
Since I don't have control over the number of columns that can be uploaded by the user, I need something which can handle any number of columns. I don't look forward to do any processing on the workbook other than displaying the data on teh screen.
Can someone please suggest on this ?
Do you have any further questions or concerns about loading a dynamic number of columns from an Excel file?
Please see the attached sample for a demonstration of using an IEnumerable collection of IDictionary objects. This data then needs to be converted in to a form that the grid can understand.
The sample is a modified version of another sample I've created that loads data from an XML file that has a dynamic amount of columns. It uses an extender method to convert the data in to a representation that can be bound to the grid.
I used the following blog article for the extender method. Please note that this article is neither owned nor maintained by Infragistics:
<http://blog.bodurov.com/How-to-bind-Silverlight-DataGrid-from-IEnumerable-of-IDictionary>
Please let me know if you have any further questions or concerns about this approach.
