2725
Attempting to Style WebCombo
I have a webcombo with Columns: Code,Title and values: row1: blank  Row2: Yes  row3: No
When it comes up the scroll bars are visible and the no is partially visible. i cannot seem to increase
the size of the dropdown frame . if i change the dropdown height it changes the  height of the rows.
I don't want the rows resized.
Gary
  • 170
    Hi Gary,
    Just a few ideas for you to try, and a few questions.
    ·       Are you setting the 'DropDownFrame' size at design time or programmatically?
    ·       Are you setting the correct properties? (sorry if this is a silly question.)
    o      VB Example: WebCombo1.DropDownLayout.DropdownWidth = System.Web.UI.WebControls.Unit.Pixel(500) This will set the dropdownframe to a width of 500px.(.DropdownHeight for height) I put it in the page_load to test it and it did work.
    ·       If you are setting it at design time then, are you Setting the ‘StyleSetName’, ‘StyleSetPath’ or ‘EnableAppStyling’? I’m not sure, but I think the styleset can override your design time settings, sure I’ve had this before, but don’t quote me.
    ·       Have you checked for any bad html markup on your page by viewing source? I’m sure I have experience this before. Not sure what I deleted from the definition, but I know it was overriding my layout so a colour I tried to change in code came back at runtime.
    Hope this helps,
    PenPal1999
