75
Change header style on sort
I am having problems changing the background color of the header in a column when sorting by that column. I am trying to set the color in the
UltraWebGrid1_SortColumn function, and it appears that i can set the value ok, but it is not doing the display. the code is as follows.
Private Sub UltraWebGrid1_SortColumn(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.SortColumnEventArgs) Handles UltraWebGrid1.SortColumn
Dim uwgcol As Infragistics.WebUI.UltraWebGrid.UltraGridColumn
For Each uwgcol In UltraWebGrid1.Columns
If uwgcol.SortIndicator <> Infragistics.WebUI.UltraWebGrid.SortIndicator.None Then
uwgcol.Header.Style.BackColor = Color.Aquamarine
Else
uwgcol.Header.Style.BackColor = Color.Moccasin
End If
Next
End Sub
Any thoughts on what i am doing wrong and why i can't set the background color?
