I have a stored procedure that returns two temp tables which are then populated to a hierarchical WebGrid. I can return rows with no issues, as you can see by my response.write() lines. However the WebGrid still displays "No data to display", even though all of this is happening during the UltraWebGrid1_DataBinding() event. I can also confirm that the stored procedure works perfectly in SQL, as it builds the tables exactly to my specs. Help?
Private Sub UltraWebGrid1_DataBinding(ByVal sender As Object, ByVal e As System.EventArgs) Handles UltraWebGrid1.dataBinding 'Get the StudyID Dim StudyID As Integer = Request.QueryString("StudyID") If Not StudyID = Nothing Then StudyID_Textbox.Text = StudyID End If 'Build the dataset for the UltraWebGrid Dim conn As SqlConnection = New SqlConnection(ConnectionString.getAppropriateString()) Dim cmdMonthly As New SqlDataAdapter("sp_rs_View_All_Participant_Results " & StudyID, conn) Dim dsSpecimenDetails As New System.Data.DataSet cmdMonthly.Fill(dsSpecimenDetails, "TEMP_ParticipantLabResults") cmdMonthly.Fill(dsSpecimenDetails, "TEMP_ParticipantSpecimens") 'Check for data If dsSpecimenDetails.Tables("TEMP_ParticipantLabResults").Rows.Count = 0 Or dsSpecimenDetails.Tables("TEMP_ParticipantSpecimens").Rows.Count = 0 Then Response.Write("no rows returned") Else 'Ensure 61 total rows are returned Response.Write(dsSpecimenDetails.Tables("TEMP_ParticipantLabResults").Rows.Count) Response.Write(dsSpecimenDetails.Tables("TEMP_ParticipantSpecimens").Rows.Count) End If Try dsSpecimenDetails.Relations.Add("TEMP_ParticipantLabResults", dsSpecimenDetails.Tables("TEMP_ParticipantLabResults").Columns("SpecimenNumber"), dsSpecimenDetails.Tables("TEMP_ParticipantSpecimens").Columns("SpecimenNumber")) Catch ex As System.Exception Response.Write(ex.Message) End Try Me.UltraWebGrid1.DataSource = dsSpecimenDetails.Tables("TEMP_ParticipantLabResults").DefaultView End Sub 'UltraWebGrid1_DataBinding
