Hi all,
We recently upgraded our controls to 9.2.20092.2056 in order to fix the random exception being generated by webUi.Shared that was fixed recently, however now we are having an even bigger problem. We can no longer run the site at all as whenever the page loads we get:
[NullReferenceException: Object reference not set to an instance of an object.] Infragistics.WebUI.CalcEngine.TokenInfo.get_Reference() +29 Infragistics.WebUI.CalcEngine.TokenInfo..ctor(ReferenceHolder referenceHolder, IUltraCalcReference reference, TokenInfo deltaScope) +151 Infragistics.WebUI.CalcEngine.TokenInfo.GetDependantsHelper(TokenInfo tokenLHS, ReferenceHolder RHS, HashSet processedLHS, HashSet result) +366 Infragistics.WebUI.CalcEngine.TokenInfo.GetDependants(AncestorMapCache cache, TokenInfo tokenLHS, ReferenceHolder RHS) +177 Infragistics.WebUI.CalcEngine.TokenInfo.GetDependants(AncestorMapCache cache, ReferenceHolder LHS, ReferenceHolder RHS) +58 Infragistics.WebUI.CalcEngine.UltraCalcEngine.DetectCircularity(AncestorMapCache cache, ReferenceHolder formulaReference) +101 Infragistics.WebUI.CalcEngine.UltraCalcEngine.VerifyAncestorMap() +549 Infragistics.WebUI.CalcEngine.UltraCalcEngine.CleanTopologicalEventQueue(Int64 ticks) +431 Infragistics.WebUI.CalcEngine.UltraCalcEngine.Recalc(Int64 ticks, Boolean isStartOfRecalcOperation) +99 Infragistics.WebUI.CalcEngine.UltraCalcEngine.Recalc(Int64 ticks) +42 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.ReCalcInternal(Int64 ticks, Boolean ignoreSuspend) +228 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.ReCalc(Int64 millis) +430 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.ReCalc(Boolean ignoreSuspend) +38 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.ReCalc() +42 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.ReCalcSynchronous() +71 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.VerifyReCalc() +69 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.DirtyCalc(IUltraCalcReference reference, ValueDirtiedAction action) +108 Infragistics.WebUI.UltraWebCalcManager.UltraWebCalcManager.Infragistics.WebUI.CalcEngine.IUltraCalcManager.AddReference(IUltraCalcReference reference) +118 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.RegisterWithCalcManager() +209 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.set_CalcManager(IUltraCalcManager value) +92 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt(Control container) +216 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt(Control container) +278 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt(Control container) +278 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt(Control container) +278 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt(Control container) +278 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.FindCalcManagerAndRegisterWithIt() +347 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.Control_Load() +179 Infragistics.WebUI.UltraWebGrid.UltraWebGrid.OnLoad(EventArgs e) +45 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
It seems to think a grid referenced in the calc manager is no longer there, however there aren't any grids taht get deleted that would have a reference to the calc manager (there are some that are on tabs that are hidden for most users, but that has never caused a problem before). I tried removing the webcalcmanager and readding it to the page, but that had no effect. Any suggestions on how to fix this would be greatly appreciated.
Hi Andy,
Would you try with the latest service release for your version, this issue should be resolved.
Thanks.
Yes, I've got this too. It's driving me nuts. It appears that SourceSafe is Infragistics greatest ally.
The procedure is: Check the form in, check it out, make a change, find an exception thrown by Infragistics in the designer, rollback, repeat times 3 days.
Please, can you submit a support request. It needs to be investigated further.
Thank you!
