300
Manually firing NodeChanged event.
Is there a way to manually make sever side NodeChanged event fire for a specific Node?
I make some changes to the Tag property of the node from Client side and i would like to make the server aware that the Tag property of a specific Node has changed. The Text of the Node does not change. Is there a trick i could apply, change for example another property of a TreeNode in order to make Server NodeChanged event fire?
Thanks in advance,
Konstantinos
