45
Problems with Postbacks and LoadOnDemand
i'm using the UltraWebTree Component (V. 9.1) with these Properties:
<ignav:UltraWebTree ID="wtLog" runat="server" OnDemandLoad="wtLog_DemandLoad"
LoadOnDemand="ManualSmartCallbacks" Height="297px" Indentation="20" TargetUrl=""
ImageDirectory="~/images/infragistics/" EnableViewState="true"
Width="163px" WebTreeTarget="ClassicTree" ExpandAnimation="None"
onnodeclicked="wtLog_NodeClicked" ExpandOnClick="True">
<ClientSideEvents NodeClick="wtLog_NodeClick" />
</ignav:UltraWebTree>
But when i perform any postback, all Nodes become collapsed.
On Page_Load i add some root nodes if !PostBack. OnDemandLoad i add folder nodes / file nodes.
Node newNode = new Node()
Text = GetShortLogFileName(file.Name),
ShowExpand = false,
DataPath = file.FullName,
ToolTip = file.Name,
Tag = "file",
ImageUrl = "~/images/730-list.gif"
nodes.Add(newNode);
via client side event wtLog_NodeClick i stop the node-click-postbacks when tag != "file"
function wtLog_NodeClick(treeId, nodeId, button) {
var tree1 = igtree_getTreeById(treeId);
var Nodeclick = igtree_getNodeById(nodeId);
if (Nodeclick.getTag() != "file") {
tree1.CancelPostBack = true;
</script>
But the only thing what happen, when i click on a file node is: Page_Load, Page_Unload
wtLog_NodeClicked will not be called. And all nodes are gone after this postback.
Alle nodes are also gone, when i perform a postback via an other control e.g. a button.
please help me with this issue.
regards.
  • 12025
    This article details the problem and explains what you are experiencing.
    http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9685
    This is a known issue, unfortunately and the tree is designed to no maintain state in case of async postbacks. There are two approaches I would recommend:
    1. Make the page non-postbackable, meaning the user can only navigate away from is to a different section of the site, and any page related operations are done via AJAX only, no fully page post back.
    2. Maintain the tree state yourself using a hidden field and take into account node expansions by the user. Once there is a postback you can bring the tree back to the state using either the server or the client API.
    -Taz.
