395
igcmbo_setDisplayValue firing events when not asked to
We're a version or two behind (trying to get approval for a new version!), but I just wanted to see whether this particular issue has been fixed/updated in the newer versions, because I haven't found mention of it anywhere.
We use igcmbo_setDisplayValue in our Javascript after getting new data back from the server. We call it very simply: webCombo.setDisplayValue(nodeValue, false)
The "false" parameter is to prevent events from firing (the three possible parameters are: newValue, bFireEvent and bNoPostUpdate)
This parameter, however, is not quite respected.
There is a call to: this.grid.setActiveRow(cell.Row); in igcmbo_setDisplayValue. This is incorrect - it is missing parameters.
setActiveRow takes three parameters: row, force and fireEvents. If fireEvents is undefined, it gets set to true:
    if(typeof(fireEvents)=="undefined")
        fireEvents=true;
It should have called: this.grid.setActiveRow(cell.Row, undefined, bFireEvents); instead.
The symptom we end up with is that the whole frame jerks around to get the WebCombo in view.
I'm going to try to bypass it by setting a secret property (e.g. webCombo.grid.suppressFireEvent) and overriding grid.setActiveRow with a near-identical prototype that checks the secret property when checking fireEvents.
  • 395
    The workaround worked.
    I overrode the grid's setActiveRow prototype:
    function overrideSetActiveRow() {
        // Workaround for igcmbo_setDisplayValue jerking the screen around
        igtbl_Grid.prototype["setActiveRow"] =
            function(row, force, fireEvents) {
                if (!this.Activation.AllowActivation || this._insideSetActive)
                    return;
                if (typeof (fireEvents) == "undefined") {
                    if (this.suppressFireEventsOnce) {
                        fireEvents = false;
                        this.suppressFireEventsOnce = false;
                    else
                        fireEvents = true;
    ...the rest of the setActiveRow source code... }  }
    Run the override in your page's BLOCKED SCRIPT
        <script type="text/javascript">overrideSetActiveRow();</script>
    We then set our new "suppressFireEventsOnce" property whenever we want to make sure that the web combo will not gain focus:
    webCombo.grid.suppressFireEventsOnce = true;
    No more on-screen jumping about when we set the WebCombo's value through JavaScript.
