733
Can't get webgrid to display hierarchical data
Basically I dropped a webgrid on the page and added this code:
comdata.Transaction.LoadTransactions()
comdata.TransactionDetail.LoadTransactionDetails()
gridTest.DisplayLayout.ViewType = ViewType.Hierarchical
gridTest.DataSource = comdata
gridTest.DataMember =
"Transaction"
gridTest.DataBind()
The comdata dataset has a relationship defined between Transaction and TransactionDetail.  When I debug the code, the grid shows two bands with the child band having the name of the relationship (FK_Transaction_TransactionDetail).  However the grid only displays the top band (transaction) with no expansion indicators.  A call to gridTest.ExpandAll() does nothing either.  This is webgrid v 7.3.  Thanks in advance,
Bob
  • 733
    I think I figured out what was going on.  I have a strongly typed dataset with three datatables and two relations between them.  The webgrid sees the correct relationship between the two tables I wanted to display data from, but it does not allow the user to expand the rows from the parent table (no expansion indicator and expandall does nothing).  By adding a call to dataset.Relations.Clear() and then manually adding the relation back in code, the webgrid behaves properly.  Surely this is not by design.  I did notice that if the dataset has only one relation at design time, then the grid behaves properly as well.
