My grid doesnt load any data when the page is first loaded but when I do a scroll (using ajax) the data shows up.
Any ideas?
No problem,
Hopefully the infragistics guys reading this will foward that issue to their development teams and get it resolved in a future release.
Thanks for the response, and you are right. If I set the height to a specific number of pixels the problem goes away. Unfortunately the grid height can vary so it's difficult to tell what the height needs to be (and I want to avoid scroll bars). I may have to come up with a method to count to rows, multiply that times the row height and then add in the headers.
Jarrod,
When expermenting with this after I got it to work I wanted to test the width and height using percentages rather than pixels (leaving them blank makes the grid fully expanded) I wanted to have the grid use percentages because of screen resolution situations. It works fine when using width=100% (ect..) but when I set the height to use a percentage I got the same error you did where only the headers would show up so Im going to have to use a solid pixel number. Perhaps this is your problem as well?
Correction that did work. It fixed it, dont ask me why but when I put the form tag next to the body rather than in my table (the object datasource was still inside the form tag) it fixed it.
The new code.
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %><%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head><title>AMWeb</title><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><link href="amweb_styles1.css" rel="stylesheet" type="text/css" /><script language="JavaScript" type="text/JavaScript"><!--function MM_swapImgRestore() { //v3.0 var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a)&&x.oSrc;i++) x.src=x.oSrc;}function MM_preloadImages() { //v3.0 var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array(); var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++) if (a.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}}function MM_findObj(n, d) { //v4.01 var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) { d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);} if(!(x=d)&&d.all) x=d.all; for (i=0;!x&&i<d.forms.length;i++) x=d.forms; for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers.document); if(!x && d.getElementById) x=d.getElementById(n); return x;}function MM_swapImage() { //v3.0 var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3) if ((x=MM_findObj(a))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}}//--></script></head><body onLoad="MM_preloadImages('images/buttonsideover.gif','images/logoutover.gif')"><form name="mainForm" runat=server id="Form1"><!-- header and footer table --><table height="100%" border="0" cellspacing="0" cellpadding="0" class="outertable" style="width: 100%"><tr><td class="top"><!-- start of header table --> <table width="100%" border="0" cellpadding="0" cellspacing="0" class="headerback2"> <tr> <td> <table border="0" cellspacing="0" cellpadding="0" class="headertable"> <tr> <td rowspan="2" class="seal"><img src="images/seal2.gif" width="83" height="75"></td> <td class="title1"><img src="./images/amweb.gif"></td><td class="logout"><a href="#"><img src="images/logout.gif" name="logout" width="64" height="18" border="0" id="logout" onMouseOver="MM_swapImage('logout','','images/logoutover.gif',1)" onMouseOut="MM_swapImgRestore()"></a></td></tr><tr><td colspan="2" class="nav"> <table border="0" cellspacing="0" cellpadding="0" class="navtable"><tr><%page_security();%></tr></table></td></tr></table></td> <td class="headeredge" width="10"><img src="images/headeredge.gif" width="10" height="57"></td> </tr></table><!-- end of header table --><!-- content table --><table border="0" cellpadding="0" cellspacing="0" class="containertable1"><tr><th>Availibilty Matrix - FY08 - 20/Dec/07 (specific filter applied)</th></tr><tr><td> </td></tr><tr><td style="height: 109px"><table border="0" cellspacing="0" cellpadding="0" class="tablemargin1"> <tr> <td class="cell2">Tab: <select id="Select4" name="tabs"> <option selected="selected">5 Year Cycle</option> <option>Det Level Detail</option> <option>C12 C26 Drilldown</option> <option>Coded ETT</option> <option>State FSA by DET Roll Up</option> <option>SRC to FSA Rollup</option> <option>State Rollup Sort</option> <option>AK</option> </select></td> <td> <!-- button --><div class="button" onMouseOver="MM_swapImage('go','','images/buttonsideover.gif',1)" onMouseOut="MM_swapImgRestore()"><a href="#">Go</a></div><div class="buttonside"><img src="images/buttonside.gif" name="go" width="10" height="18" id="go"></div><!-- end button --></td> </tr></table><table border="0" cellspacing="0" cellpadding="0" class="tablemargin1"> <tr> <td class="cell2">Custom Filter: <select id="Select1" name=""> <option selected="selected">bde group</option> <option>Patch</option> <option>CMD Level</option> <option>UIC</option> <option>Unit Type</option> <option>State</option> <option>EFF Date</option> <option>Unit Name</option> <option>Unit ABBR</option> </select> <select id="Select2"> <option selected="selected">equals</option> <option>does not equal</option> <option>is greater than</option> <option>is less than</option> </select> <input id="Text1" type="text" /> <select id="Select3"> <option selected="selected">equals</option> <option>does not equal</option> <option>is greater than</option> <option>is less than</option></select> <input id="Text2" type="text" /></td> <td><!-- button --><div class="button" onMouseOver="MM_swapImage('filter','','images/buttonsideover.gif',1)" onMouseOut="MM_swapImgRestore()"><a href="#">Filter</a></div><div class="buttonside"><img src="images/buttonside.gif" name="filter" width="10" height="18" id="filter"></div><!-- end button --></td> </tr></table><table border="0" cellspacing="0" cellpadding="0" class="buttontable1"> <tr> <td><!-- button --><div class="button" onMouseOver="MM_swapImage('export','','images/buttonsideover.gif',1)" onMouseOut="MM_swapImgRestore()"><asp:LinkButton ID="lbExcel" runat="server" OnClick="lbExcel_Click">Export to Excel</asp:LinkButton></div><div class="buttonside"><img src="images/buttonside.gif" name="export" width="10" height="18" id="export"> </div><!-- end button --></td><td><!-- button --><div class="button" onMouseOver="MM_swapImage('print','','images/buttonsideover.gif',1)" onMouseOut="MM_swapImgRestore()"><a href="#">Print</a></div><div class="buttonside"><img src="images/buttonside.gif" name="print" width="10" height="18" id="print"></div><!-- end button --></td><td><!-- button --><div class="button" onMouseOver="MM_swapImage('workingV','','images/buttonsideover.gif',1)" onMouseOut="MM_swapImgRestore()"><a href="#">Make Working Version</a></div><div class="buttonside"><img src="images/buttonside.gif" name="workingV" width="10" height="18" id="workingV"></div><!-- end button --></td> </tr></table> </td></tr></table><span style="position:relative;top:-7%;left:2%"> <asp:ObjectDataSource ID="ObjectDataSource1" runat="server" SelectMethod="fill" TypeName="Amweb.Data.AvailabilityMatrixDAL" OldValuesParameterFormatString="original_{0}"> <SelectParameters> <asp:Parameter DefaultValue="OLD DATA" Name="scenarioId" Type="String" /> <asp:Parameter DefaultValue="08" Name="fyStart" Type="UInt32" /> </SelectParameters> </asp:ObjectDataSource> <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" DataSourceID="ObjectDataSource1" Height="550px" OnInitializeRow="UltraWebGrid1_InitializeRow" Width="1165px" EnableCrawlerDetection="False" Browser="Xml"> <Bands> <igtbl:UltraGridBand> <RowEditTemplate> <br /> <p align="center"> <input id="igtbl_reOkBtn" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px" type="button" value="OK" /> <input id="igtbl_reCancelBtn" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px" type="button" value="Cancel" /></p> </RowEditTemplate> <AddNewRow View="NotSet" Visible="NotSet"> </AddNewRow> <RowTemplateStyle BackColor="Window" BorderColor="Window" BorderStyle="Ridge"> <BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px" WidthTop="3px" /> </RowTemplateStyle> <Columns> <igtbl:UltraGridColumn BaseColumnName="Databound Col0" IsBound="True" Key="Databound Col0"> <Header Caption="Databound Col0"> </Header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Databound Col1" DataType="System.Int32" IsBound="True" Key="Databound Col1"> <Header Caption="Databound Col1"> <RowLayoutColumnInfo OriginX="1" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="1" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Databound Col2" IsBound="True" Key="Databound Col2"> <Header Caption="Databound Col2"> <RowLayoutColumnInfo OriginX="2" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="2" /> </Footer> </igtbl:UltraGridColumn> </Columns> </igtbl:UltraGridBand> </Bands> <DisplayLayout FixedHeaderIndicatorDefault="NotSet" HeaderTitleModeDefault="Always" Name="UltraWebGrid1" RowHeightDefault="20px" SelectTypeRowDefault="Single" Version="3.00" SortingAlgorithmDefault="NotSet" IndentationTypeDefault="Flat" LoadOnDemand="Xml" XmlLoadOnDemandType="Virtual" AllowDeleteDefault="Yes" AllowUpdateDefault="Yes"> <ActivationObject BorderColor="Black" BorderWidth="" BorderStyle="Dotted"> <BorderDetails WidthLeft="0px" WidthRight="0px" /> </ActivationObject> <RowStyleDefault BackColor="#BCDAE8" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px"> <BorderDetails ColorLeft="188, 218, 232" ColorTop="188, 218, 232" /> <Padding Left="3px" /> </RowStyleDefault> <FilterOptionsDefault> <FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px"> <Padding Left="2px" /> </FilterOperandDropDownStyle> <FilterHighlightRowStyle BackColor="#151C55" ForeColor="White"> </FilterHighlightRowStyle> <FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Width="200px"> <Padding Left="2px" /> </FilterDropDownStyle> </FilterOptionsDefault> <HeaderStyleDefault BackColor="#5BA1C2" BorderStyle="Solid" BorderColor="Black" ForeColor="White"> <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" /> </HeaderStyleDefault> <FrameStyle BorderColor="#999999" BorderStyle="None" BorderWidth="3px" Width="1165px" Cursor="Default" Height="550px"> </FrameStyle> <ClientSideEvents AfterCellUpdateHandler="UltraWebGrid1_AfterCellUpdateHandler" /> <SelectedRowStyleDefault BackColor="#9BBCCC" ForeColor="White"> </SelectedRowStyleDefault> <RowAlternateStyleDefault BackColor="#E9E9F7"> <BorderDetails ColorLeft="233, 233, 247" ColorTop="233, 233, 247" /> </RowAlternateStyleDefault> </DisplayLayout> </igtbl:UltraWebGrid> </span> </td></tr></table><!-- end header and footer table --></form></body></html>
I have since changed that and its not the issue. Are there known issues that might cause this?
I am binding to a DataTable.
