Does anyone know if it's posible to show KPIs in the upcoming pivotgrid?
I'm also wondering what kind of databinding it will support?
ThanksRune
Hi Rune,
I'm not sure if the KPIs will be finished for 10.1 release, but the architecture is built to support them.
Save and load is upper on our feature implementation list, so there is a high possibility to have them ready.
Thanks,George
Okay, thanks.
But will the KPIs be supportet in the final release?
Just another thing, will it be possible to save and load the layout/fields of the pivotgrid (filter, row, column and data fields) ?
The KPIs are not supported yet.
In the CTP you can use XMLA Data provider to connect directly from Silverlight or you can use ADOMD library to connect through it. In the second case you will need the Adomd provider that is included in the Samples bundled in the CTP.
