I have a checkbox in templated column in a sortable UltraWebGrid. User can submit changes for the rows that are checked. The problem is when the user check some of the boxes and then sort by clicking the column header, some of the checked boxes become unchecked, and after several sorting, all boxes become uncheced.
So my question is that is how to maintain those checkboxes checked after sorting.
Thanks,--Vincent
Did you find the solution to the above issue. I have same problem. I appreciate your response.
Katta
I have the same problem occuring with checkboxes. Did you find the solution. I appreciate your response.
