835
Checkboxes and Image
It seems that I cannot have both Checkboxes and Images on a popup menu.  Is that true?
I come to this conclusion by having a working popup menu with images then setting the checkboxes property of the menu to true and see the images go away.
So these characteristics are mutually exclusive???
  • 7694
    You  can render check box and image  together  when you   enable check  box  selection of menu and in text of item you  put text in Text  =”<img src=’image’/>TEXT” property.  In  value of the text you  can put HTML elements that will be render propely.
    Ivan Baev
