Hi All,
I have spent hours and days to get post back for chekbox inside a ultrawebgrid (Using Sharepoint Webpart) using updatecell event.But every time i click checkbox it making duplicate columns with no data.
No idea really what the hell is going on.
I found some wwhere that there is no way of firing an event for manually added checbox inside ultrawebgrid.
Please help me.
Million Thanks in advance.
Hi Rado,
Thanks for quick response.
following is the code
Imports SystemImports System.DataImports System.Data.OracleClientImports Infragistics.WebUI.UltraWebGridImports System.ConfigurationImports CampAddressList.CustomItemTemplatePartial Public Class _Default Inherits System.Web.UI.Page Dim dt As New DataTable() Dim dc As DataColumn = New DataColumn("ADDRESS", Type.GetType("System.String")) Dim otDs As New DataSet Dim PIds As New StringBuilder 'collection of PID's from Dataset Protected _param As DataTable = Nothing Dim strconnection As String Dim conn As New OracleConnection Public ReadOnly Property Param() As DataTable Get Return _param End Get End Property
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load dt.Columns.Add(dc) 'Add column to to data table (dt) to get selected address
If Not Page.IsPostBack = True Then
strconnection = System.Configuration.ConfigurationManager.AppSettings("CONN") conn = New OracleConnection(strconnection)
Try
Dim ds As New DataSet Dim sString As String = " XXXXXXXXXXXXX "
conn.Open() Dim da As New OracleDataAdapter(sString, conn)
da.Fill(ds, "PRIMARY")
Me.UGrid.DataSource = ds.Tables("primary") UGrid.DataBind()
Session("Data") = ds
createTemplateColumnALL()
ClientScript.RegisterStartupScript(Me.GetType(), "javacript:HideCheckBox();", True)
conn.Close() conn.Dispose()
Catch ex As Exception lblMsg.Visible = True lblMsg.Text = ex.Message End Try End If End Sub
Private Sub createTemplateColumnALL() 'Create a template column. Dim colAll As New TemplatedColumn(True) colAll.Header.Caption = "ALL" colAll.Key = "CheckAll" 'Assign the template control to the template column. colAll.CellTemplate = New CustomItemTemplate() UGrid.Columns.Add(colAll, True) End SubEnd Class
COde in Class file:
Public Class CustomItemTemplate Implements System.Web.UI.ITemplate 'Here you can put whatever control you want. Public Sub InstantiateIn(ByVal container As System.Web.UI.Control) Implements System.Web.UI.ITemplate.InstantiateIn Dim checkBoxAll As New CheckBox() checkBoxAll.Checked = False checkBoxAll.Visible = True checkBoxAll.AutoPostBack = True container.Controls.Add(checkBoxAll) End SubEnd Class
Can you post your code related to the grid please, maybe it will help to see what is going on with your code, I mean aspx and code - behind.
Rado,
Thank you very much for your response.i used above code but i cant see the checkbox inside column.
Please help me .
Attaching the sample.
I've put together a small sample in order to demonstrate how to create a template column in code-behind.
Please see the sample.
Le me know if you still have issue with.
