1375
Value Converters
Should the numeric web mask work with ValueConverters?
this is the error i got
The new assigned value: 0 is not of specified type: Double
  • 760
    Suggested Answer
    Hi spicish22,
    The XamWebNumericEditor control requires the numeric type which is specified at ValueType property.
    By default it is - Double.  You can set double numbers in this way:
    numericEditor.Value = 23d;
    numericEditor.Value = (Double) 23;
    The most complicated way is using a value converter. The control can work with converters.
     Doychin Dochev
