Is there anyway to make the ultrawebgrid scale to fit the available browser area automatically? SO as I resize the browser window, the grid scales with it?
regards,
craig wight.
It works fine.
I have used unit.percentage to set all visible column widths and they are scaling now with the broswer window.
Thanks.
Ok thanks for your help on this I will try it using percentages for the column widths.
Craig Wight.
I just tried it. I see that when all the widths were blank, it didn't work. When I change one of them to width="20%", they all worked. Something's not exactly right, but it looks like you can get it to work.
Ed
Do you have the width of the column specified? If so, it won't change. If you leave it empty, it should change. You can also set the width of the column to width="12%" and then it will also change dynamically.
Thanks for your answer.
I have tried this but the columns stay the same width all the time - do you know of a method by which I can scale the columns dynamically as the browser resizes?
Thanks again.
