Hello,I try to change the CssClass property of a cell row from the event initializerow. The class is taken into account in the resulting page, but it is not applied.Why? and how to apply the classroom?
Sincerely
Hello,thank you it works
Can you try the following code:
<style type="text/css">
.MyClass{
background-image :none;
background-color:Black !Important;
</style>
This is my code -behind:
e.Row.Cells[0].Style.CssClass = "MyClass"; which is put in Initialize Row
It should works now.
yes as it works by cons if you want to use the CssClass property that does not work.
e.row.Cells[0].Style.CssClass = "MyClass";
I have a suggestion:
void UltraWebGrid1_InitializeRow(object sender, RowEventArgs e)
//You can get a reference to each cell form the given row of the grid and apply style.
e.Row.Cells[0].Style.BackColor = Color.Blue;
e.Row.Cells[0].Style.BorderColor = Color.Red;
Hope it helps you.
