Hello all,
1. I have a webgrid that have many rows so when I scroll down to the bottom, the column headers are no longer visible. What is the property that I can set to make it fixed when I scroll down to the bottom.
2. I also like to have the first column value fixed as well so when I scroll over horizontally, I can still see the value from the first column (column 1 contains the ID so I need that ID to be visible so I can see which record I'm viewing).
Thanks in advance!
HS2
I may have had the same problemhttp://forums.infragistics.com/forums/p/2426/15260.aspx#15260
check that, see if it helps
