1000
WebCombo with AutoGenerateColumns false problem
I have the follwing  WebCombo:
    <igcmbo:WebCombo ID="WebCombo1" Version="4.00" runat="server" Height="16px" Width="500px" Editable="False" ComboTypeAhead="None" DataTextField="CASTELLANO" DataValueField="ID" EnableAppStyling="True" StyleSetName="Claymation" DisplayValue="CASTELLANO">
        <Columns>
            <igtbl:UltraGridColumn HeaderText="ID" Key="ID" IsBound="True" BaseColumnName="ID">
                <footer key="ID"><RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo></footer>
                <header key="ID" caption="ID"><RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo></header>
            </igtbl:UltraGridColumn>
            <igtbl:UltraGridColumn HeaderText="CASTELLANO" Key="CASTELLANO" IsBound="True" BaseColumnName="CASTELLANO">
                <footer key="CASTELLANO"><RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo></footer>
                <header key="CASTELLANO" caption="CASTELLANO"><RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo></header>
        </Columns>
        <DropDownLayout DropdownWidth="" BorderCollapse="Separate" RowSelectors="No" RowHeightDefault="20px" DropdownHeight="" ColHeadersVisible="No" GridLines="None" Version="4.00" AutoGenerateColumns="false" >
            <HeaderStyle BorderStyle="Solid" BackColor="LightGray">
                <BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails>
            </HeaderStyle>
        </DropDownLayout>
        <ExpandEffects ShadowColor="LightGray" Type="Slide"></ExpandEffects>
    </igcmbo:WebCombo>
On page load I have the following code:
Dim ds As DataSet = negReturnMessage.GetDataSet()
            ds.Tables(0).TableName = "TEST"
            WebCombo1.DataMember = "TEST"
            WebCombo1.DataSource = ds
            WebCombo1.DataBind()
Now the dropdown isn't working and I can't see results, when I change the AutoGenerateColumns true I can see clearly all the columns and the results.
What is happening? What am I doing wrong?
  • 45049
    Verified Answer
    The IsBound property is likely the cause of your issue.
    By setting this property to true, you're saying "this column was defined by automatically generated columns."  As a result, when you have AutoGenerateColumns set to false, WebCombo sees these columns, determines they were automatically generated, and discards them since you're not using automatically generated columns.  With all of your columns having this property set to true, they're all discareded.
    Set this IsBound property to false instead, for this to work with AutoGenerateColumns set to false.
