620
Running Total
Any help on this would be great. I have a collection bound to the grid that includes the sales for each day
Date                Net Sales
1/Nov/2009   10.00
2/Nov/2009   15.00
3/Nov/2009   50.00
I have added a template column called Sales To Date and I need to show the running totals in this column
Date                Net Sales    Sales To Date
1/Nov/2009   10.00              10.00
2/Nov/2009   15.00              25.00
3/Nov/2009   50.00              75.00
any thoughts on how to achive this without changing the underlying object.
David
  • 6475
    Hi David,
    I'm not sure if you still need help with this, but one way to do this is using a converter to calculate the value for the given row. Attached is a quick sample that demonstrates it.
    Note that the "Sales To Date" column is not bound to a field in the data source. The attached sample uses 9.2 version of XamWebGrid. If you're using a newer version, you'll have to replace the TemplateColumn with UnboundColumn.
    Hope that helps,
    Sample.zip
