Can anyone show me how to make it work. What I want to do is to update the Label2 with the latest time and refresh (async) the WebAsyncRefreshPanel1 at the Button2_Click event. So, then, Label1 is refreshed with the same timestamp as Label2. The problem is that after using WebAsyncRefreshPanel1.AddLinkedRequestTrigger("*Button2"); only Label1 is updated, but not Label2. The behavior is reversed when that statement is removed. I'm using a Master Page. And the Content Page is not AJAX-enabled webpage. Please assist. Thanks.
Here is the Default.aspx page.
<%@ Page Title="" Language="C#" MasterPageFile="~/MasterPage.master" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %><%@ Register Assembly="Infragistics35.WebUI.UltraWebTab.v8.2, Version=8.2.20082.2110, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebTab" TagPrefix="igtab" %><%@ Register Assembly="Infragistics35.WebUI.Misc.v8.2, Version=8.2.20082.2110, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.Misc" TagPrefix="igmisc" %><%@ Register Assembly="Infragistics35.Web.v8.2, Version=8.2.20082.2110, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %> <asp:Content ID="Content1" ContentPlaceHolderID="head" Runat="Server"></asp:Content><asp:Content ID="Content2" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server"><igtab:UltraWebTab ID="UltraWebTab1" runat="server" Width="400px" Height="300px" > <Tabs> <igtab:Tab Text="Tab 1" Key="Tab1" > <ContentTemplate> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Height="80px" Width="80px" > <asp:Label runat="server" ID="Label1" Text="Time: " /> <asp:Button ID="Button1" runat="server" Text="Button" onclick="Button1_Click" /> </igmisc:WebAsyncRefreshPanel> </ContentTemplate> </igtab:Tab> <igtab:Tab Text="Tab 2" Key="Tab2"> <ContentTemplate> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel2" runat="server" Height="80px" Width="80px" > <asp:Label runat="server" ID="Label2" Text="Time: " /> <asp:Button ID="Button2" runat="server" Text="Button" onclick="Button2_Click" /> </igmisc:WebAsyncRefreshPanel> </ContentTemplate> </igtab:Tab> <igtab:Tab Text="Tab 3" Key="Tab3"> <ContentTemplate> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel3" runat="server" Height="80px" Width="80px" > <asp:Label runat="server" ID="Label3" Text="Time: " /> <asp:Button ID="Button3" runat="server" Text="Button" onclick="Button3_Click" /> </igmisc:WebAsyncRefreshPanel> </ContentTemplate> </igtab:Tab> </Tabs> </igtab:UltraWebTab></asp:Content>
Here is the Default.aspx.cs page.
public partial class _Default : System.Web.UI.Page{ protected void Page_Load(object sender, EventArgs e) { Label1.Text = "Tab 1 is here"; Label2.Text = "Tab 2 is here"; Label3.Text = "Tab 3 is here"; WebAsyncRefreshPanel1.AddLinkedRequestTrigger("*Button2"); } protected void Button1_Click(object sender, EventArgs e) { System.Threading.Thread.Sleep(3000); Label1.Text = "Page refreshed at " + DateTime.Now.ToString(); } protected void Button2_Click(object sender, EventArgs e) { System.Threading.Thread.Sleep(3000); Label2.Text = "Page refreshed at " + DateTime.Now.ToString(); Label1.Text = Label2.Text; } protected void Button3_Click(object sender, EventArgs e) { System.Threading.Thread.Sleep(3000); Label3.Text = "Page refreshed at " + DateTime.Now.ToString(); }}
