560
A few questions
A few questions:
1) If we don't supply the HeaderText for a column it automatically uses the Key as HeaderText. Can this be disabled? We now use a space as HeaderText to prevent the Key from being used. The Key as HeaderText is not really a wishful scenario, only when AutoGenerateColumns is enabled...
2) If I set the width of a column to * and the minimum width to 100, when the grid columns are wider than the available space, my star column will be collapsed further than the specified minimum width. Is this a bug?
3) When I clear the FilteringSettings.RowFiltersCollection the original itemssource is restored, but the filter options remain, is there anyway to reset them also?
4) Multiple column sorting is done by holding the ctrl key, in Windows Explorer this is done by holding the shift key. Could you make an option to specify which key can be used to sort multiple columns?
5) We found the latest SR (21 oct.), but we didn't find any sourcecode with that. Where can we get the latest source code?
Arjen
