Hi There,
Please suggest me how to achieve below requirement.
Requirement: One column have drop down for row. One more drop down need to add at Header row of that column. If user select any item from drop down of header then set selection to all row.
I used Hedear template and add combobox. But i can't bind directly any collection to this combobox. How can i bound collection recived by WCF Asyn call.
Thanks,Samir
Hi Samir,
So the easiest way in doing this would probably be to attach a Loaded event to the ComboBox, and then when its loaded, setup your binding.
<igGrid:TextColumn.HeaderTemplate>
<DataTemplate>
<ComboBox Loaded="ComboBox_Loaded" />
</DataTemplate>
</igGrid:TextColumn.HeaderTemplate>
private void ComboBox_Loaded(object sender, RoutedEventArgs e)
Binding b = new Binding("Data");
b.Source = this;
((ComboBox)sender).SetBinding(ComboBox.ItemsSourceProperty, b);
Hope this helps,
-SteveZ
