20
Create hierarchical grid dynamically
Is it possible to create a hierarchical grid dynamically, with an arbitrary number of Master-Detail levels?
Mike
  • 12025
    Hello Mike,
    Yes, you can create any number of hierarchy levels dynamically within the WebGrid. Just created the grid dynamically and add a column that has a master detail grid attached, which will allow the user to expand to the next level. Your code will look something like the following.
    //Create a grid for the level to add
    GridView secondLevelGrid = (GridView) FacesContext.getCurrentInstance().getApplication().createComponent(GridView.COMPONENT_TYPE);
    //Setup the secondLevelGridColumns here
    //Create a column that will allow user to expand to the next level
    Column masterDetailColumn = (Column) FacesContext.getCurrentInstance().getApplication().createComponent(Column.COMPONENT_TYPE);
    //set the master detail facet on the column
    masterDetailColumn.setMasterDetail(secondLevelGrid);
    //Add the column that will allow to expand to the next level to the main grid
    grid.getTemplateItems().add(masterDetailColumn);
    Hope this helps.
    Taz.
