In the SL3 grid that I use, I can bind the FontSize, FontFamily, FontStyle, FontWeight and the values are nicely propagated down to the cell.
In the XamWebGrid the values aren't propagated. I could set the values as StaticResources and then bind them in each TextBlock but that's quite a lot of work and bother. I see there's a FontSize property in the CellControl style. Is it possible to tell it to get its value from its parent (the XamWebGrid)?
Cheers.
I found a way of achieving this by hooking up on the Loaded event and doing the following:
private void OnLoaded(object sender, RoutedEventArgs e) { var cellControlStyle = new Style(typeof(CellControl)); if (CellStyle != null) { cellControlStyle.BasedOn = CellStyle; } cellControlStyle.Setters.Add(new Setter(CellControl.FontFamilyProperty, FontFamily)); cellControlStyle.Setters.Add(new Setter(CellControl.FontSizeProperty, FontSize)); cellControlStyle.Setters.Add(new Setter(CellControl.FontStyleProperty, FontStyle)); cellControlStyle.Setters.Add(new Setter(CellControl.FontWeightProperty, FontWeight)); CellStyle = cellControlStyle; }
Works OK.
