I have a grid and I want to have the whole row set to a specific colour depending on the data in it. I managed to do it in SL grid by using a column template and have the display control take all the space of the cell.
When I tried to do the same in the XamWebGrid the display control doesn't take all the cell space. It does it the first time the grid is displayed and then when I click on the grid all the display components get resized and it doesn't look like the row is coloured anymore.
I attached 2 screenshots. On the top is the SL3 grid (the one I want the XamWebGrid to look like). At the bottom is the XamWebGrid. The first screenshot is just after the grid id displayed and is like I want it to look like. The second one is taken after I clicked on the grid and the colours are all messed up.
Here's my template column definition:
<igGrid:TemplateColumn Key="Name" IsReadOnly="True" IsResizable="True" Width="SizeToCells" > <igGrid:TemplateColumn.ItemTemplate> <DataTemplate> <Grid Background="{Binding Path=Rendering.BackColor, Mode=OneWay, Converter={StaticResource ColorConverter}}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"> <TextBlock Padding="2" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Text="{Binding Path=Name}" TextWrapping="NoWrap" Foreground="{Binding Path=Rendering.ForeColor, Mode=OneWay, Converter={StaticResource ColorConverter}}" /> </Grid> </DataTemplate> </igGrid:TemplateColumn.ItemTemplate> <igGrid:TemplateColumn.HeaderTemplate> <DataTemplate> <TextBlock Text="{Binding Path=Resource.Vehicle, Source={StaticResource LocalizedStrings }}"/> </DataTemplate> </igGrid:TemplateColumn.HeaderTemplate> </igGrid:TemplateColumn>
Cheers.
So first, you should set the Column's HorizontalContentAlignment property to stretch.
Next, create a new CellControl Style and set the background to the color that you'd like.
You can then apply them to that to the specific row that you'd like
Style s = new Style(typeof(CellControl));
s.Setters.Add(new Setter(CellControl.BackgroundProperty, new SolidColorBrush(Colors.Red)));
grid.Rows[0].CellStyle = s;
Hope this helps,
-SteveZ
