Hi, I wonder if someone can point me in the right direction..
I have a webcombo dropdown which I am using to display a grid, I have Type Ahead set to extended and all works well. My issue is as follows, I am using this webcombo to select a particular client and wanted to populate other controls on the same page dependant on which client is selected. My problem comes on how to select the client I am currently highlighted on. I didn;t want a button next to the webcombo to select it and post back, so was hoping that I could either use the enter key to select the client that is currently highlighted, or the mouse click on the grid to post back to the server and populate accordingly.
What is the best/easiest way of doing this?
Hope it all makes sense
Many thanks
Richard
Hi Richard,
I think your code came incomplete and unformatted, but like you said, great minds think alike. With your idea i have solved my problem. Now the user can select the row by typing inside the webcombo and fire the event just when the user press enter, tab, or clicking in a row. Below i provide the full code i used:
.aspx code
<script id="igClientScript" type="text/javascript"><!--
//With this function, the event is fired after the user select an item by clicking in a rowfunction wcCompany_BeforeCloseUp(webComboId){ wcCompany_EditKeyDown(webComboId,0,13);}function wcCompany_EditKeyDown(webComboId,newValue,keyCode){ //if user press enter or tab if (keyCode == 13 || keyCode == 9) { var combo = igcmbo_getComboById(webComboId); if (combo.getDataValue() != null) { document.getElementById('<%# hdRowChanged.ClientID %>').value = "1"; //document.forms[0].submit(); var warp = ig$('<%# warpCompany.ClientID %>'); if(!warp) return; combo.setDisplayValue(combo.getValue()); warp.refresh(); } } else document.getElementById('<%# hdRowChanged.ClientID %>').value = "0";}--></script>
<igmisc:WebAsyncRefreshPanel ID="warpCompany" runat="server" Width="100%" Height="100%" > <asp:HiddenField ID="hdRowChanged" runat="server" Value="0" /> <igcmbo:WebCombo ID="wcCompany" runat="server" Editable="True" > <ClientSideEvents EditKeyDown="wcCompany_EditKeyDown" BeforeCloseUp="wcCompany_BeforeCloseUp" /> </igcmbo:WebCombo></igmisc:WebAsyncRefreshPanel>
In the .cs file:
protected void Page_Load(object sender, System.EventArgs e){ if (hdRowChanged.Value == "1" && wcCompany.SelectedRow!=null) { wcCompany_SelectedRowChanged(wcCompany, null); }}
protected void wcCompany_SelectedRowChanged(object sender, Infragistics.WebUI.WebCombo.SelectedRowChangedEventArgs e){ this.populateDept();}
As you can see i'm using a WebAsyncRefreshPanel, so i used the js code to refresh the panel, but the code you provide to submit the form works too.
Thanks for the idea
Johni Ecco
Hi rgparkins,
Maybe you can try use the AfterCloseUp event instead of BeforeCloseUp event.
Tony,
I have tried to use the BeforeCloseUp event, like you said, but the method isn't fired after i hit the enter key and even after click outside the combo. The method is fired only when the dropdown is closed (clicking in the arrow).
I don't want to use a button to fire the event so my problem persists.
The webcombo don't have a method to do or cancel postbacks like the webgrid have igtbl_cancelPostBack(grid); ?
Cheers,
Richard,
The magic button as I like to call it, is a 'feature' of the browser. If you have a single submit button on a form, hitting the enterkey from inside of a textbox will submit the form. Annyoing as heck when you don't want it to actually happen. Luckily, this is configurable - http://msdn2.microsoft.com/en-us/library/system.web.ui.htmlcontrols.htmlform.defaultbutton.aspx
You'll want to use a form submit (post) rather than a window.location (get) so that you preserve all of the post field data such as viewstate, and any other input field values.
Hope this helps,
-Tony
