Is there a way to auto size the window to fit the content inside it? I'm using one xamWebDialogWindow for all of my popup windows and the content will change depending on which control is calling it. I would like the popup window to auto size to so that when it has only text box in the window it auto size so to fit that and when there are 30 controls on there it will know how to auto size to that as well.
Hi MrYang,
There are two cases for XamWebDialogWindow content. The first situation is when you set XamWebDialogWindow content when create the window then DialogWindow sizes auto to the size of the content. The second situation is if XamWebDialogWindow is created and you want to change the content dynamicly then the window size doesn't fit auto to the size of the content. In this case you have to set XamWebDialogWindow Width and Height properties.
Dimitrina Siderova
