I have a ultrawebgrid which is bound to a dataset. One of the columns is a foreign key
for which I want to show a dropdownlist with valid values from the foreign key table.
I have this code in InitializeLayout:
case "DistributionTypeID": col.Hidden = false;
col.Header.Caption = "Distribution Type"; col.Width = Unit.Pixel(200); col.Type = Infragistics.WebUI.UltraWebGrid.ColumnType.DropDownList; col.DataType = typeof(int).ToString(); col.ValueList.Style.CssClass = "iggrid-valuelist";
ValueList vlDistType = col.ValueList; vlDistType.DataSource = DistributionTypes; vlDistType.DataMember = "DistributionType"; vlDistType.ValueMember = "ID"; vlDistType.DisplayMember = "Name"; vlDistType.DataBind(); col.AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.Yes; col.DefaultValue = 2;
What works:
Dropdownlist shows up properly with display text and value.
Adding a new row works as expected.
What does not work:
When updating a row, the distribution type changes are not saved. i.e; if the distribution type was "A"
and it is changed to "B", it still saves "A" to the database. All other column changes are saved.
Any suggestions are greatly appreciated.
