I read through your help files:
http://help.infragistics.com/NetAdvantage/Silverlight/Current/CLR3.5/?target=SL_xamWebGrid.html
http://help.infragistics.com/Help/NetAdvantage/Silverlight/2009.1/CLR3.5/html/SL_DataUtil.html
Is it possible to get this same type of functionality using a wcf service? it seems when i write the 'Throw New Exception('blah blah blah")' code it does not come across when you create the service reference?
is it possible to do with out re creating the class on the client?
One more thing, please refer to this excellent article by Craig Shoemaker about using the VirtualCollection in conjunction with WCF Services:
http://community.infragistics.com/silverlight/articles/using-the-virtualcollection-for-server-side-xamwebgrid-paging.aspx
Have you looked into Silverlight RIA features? Web services for Silverlight has been greatly improving. This means it is improving for usage with our controls as well, since our controls do not deviate from Microsoft standards.
If you still need help with this, please provide a little more information and I will make sure we get back to you in a speedy fashion.
Thank you,
any ideas
