25
Grouping by a Column that contains a hyperlink
NetAdvantage UltraWebGrid version 8.2.20082.2160
We have grids that display hyperlinks.  They are created in two different ways, depending on the situation.  The first creates the hyperlink as a button and creates source code that looks like this:
<C iDV="CRXU4508410">
    <![CDATA[<input type="button" style="width:100%;height:100%;" value="CRXU4508410"
             onclick="igtbl_colButtonClick(event,\'uwgResults\',null, igtbl_srcElement(event));" class="ig_7fddad5d_rcb1412" tabindex="-1" />]]>
</C>
The second creates an a href tag and looks like this:
<C>
    <![CDATA[<a href="BLOCKED SCRIPTvoid(0);" onClick="return CreateComment(\'792H000014NB0\',\'CRXU4508410\');">Add Comment</a>]]>
</C>
The columns created the first way are able to be grouped.  The columns created the second way are not.  You can drag the column header to the grouping bar, but they are still listed individually.
I notice two differences (other than the fact that one is a button and one is an href).  The first one has a value="..." and the first also has a property in the C tag.  I tried adding a value="..." to the second version, but that still didn't work.  It seems to me that the grouping is enabled by the iDV="..." property in the C tag. Is there any way to get the grouping to work on an a href tag?
  • 55
    Suggested Answer
    Hi, if you have flexibility on how the 2nd type of hyperlink created, you could have regular text in the cell that is styled to "look" like a hyperlink using CellStyle.CssClas, and then using the client side OnClick event to run the actual code.  We've completely moved to this way from having an actual hyperlink in the cell, because it solves sorting issues, etc.  This may fix your grouping issue.
