Since upgrading to the 8/17 service release, I intermittently get a NullReferenceException when clearing out (or removing ont a time) old series:
System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Silverlight.Chart.XamWebChart.a(Object A_0, NotifyCollectionChangedEventArgs A_1) at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e) at System.Collections.ObjectModel.ObservableCollection`1.RemoveItem(Int32 index) at System.Collections.ObjectModel.Collection`1.Remove(T item)System.NullReferenceException: Object reference not set to an instance of an object.at Infragistics.Silverlight.Chart.XamWebChart.a(Object A_0, NotifyCollectionChangedEventArgs A_1)at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)System.Collections.ObjectModel.ObservableCollection`1.ClearItems()at System.Collections.ObjectModel.Collection`1.Clear()
I can't narrow down a small repro yet, but will keep trying. I wanted to post to see if this was a known issue, or if you could notice anything from the stack trace to help me narrow it down or avoid it.
Thanks,Keith
Good to hear, thanks David.
thanks for reporting this. it is fixed in the current source code, so it will be resolved in the next service release.
One more note... If I keep the Scene, but null it out before clearing the Series and Axes, everything works: this.chart.Scene = null;this.chart.Series.Clear();
Works in my app as well, so a pretty easy, no-impact workaround.
OK, here's a simple repro. All code-behind. This works fine on the 9.1 release, but appeared right after I upgraded to the service release.
FYI, If you comment out the Scene, it doesn't happen.
public partial class SeriesClearRepro : UserControl{ private XamWebChart chart;
public SeriesClearRepro() { InitializeComponent(); this.Loaded += new RoutedEventHandler(SeriesClearRepro_Loaded); }
void SeriesClearRepro_Loaded(object sender, RoutedEventArgs e) { ResetChart(); ResetChart(); }
void ResetChart() { if (this.chart != null) { this.chart.Series.Clear(); this.chart.Axes.Clear(); }
this.chart = new XamWebChart(); this.chart.Scene = new Scene(); }}
