I have tried to get the window to float over html content - it does not seem to be able to do this - is this possible?
Many thanks
Zack
Hi Zack, XamWebDialogWindow is a SL component. If You have HTML host probably your application is windowless. If you want to keep HTML content visible the possible way is to use second application that is not windowless and XamWebDialogWindow inside it. This approach is attractive , but more difficult. I thunk that the easiest way is to set html content to hidden.
Kind Regards!
Mihail
Yes and No.
My SL application takes up the full screen space. I have a tab control which displays html content within some of the tabs and some tabs have pure silverlight content.
When I need input from a user - I pop up a XamWebDialogWindow to collect input data. If the currently selected tab in my tab control contains html content - the XamWebDialogWindow will either move the html content down or slide underneath it (as the html is floating on top of the SL application).
I think I am going to have to set the html content to hidden and make the dialog modal and do something with the modal background template so that it looks ok. I would prefer it however, if the dialog floated over the html content...
Hi Zack,
Is what you are trying to achieve similar to this example:
http://delicategeniusblog.com/projects/dragalicious/overlay_proto/
Angel
