hello, i am adding columns dynamically,
i re-add them on each postback in order to skip using viewstate.
even though i call grid.Columns.Clear() before re-adding, the columns get duplicated on each postback.
what is a good clean way to re-add columns dynamically on each postback without duplicating?
The method grid.Columns.Clear() should work. Please download the latest service pack and test using it. If the error still exists then please debug the code and test the number of columns after the Clear() method.
Magued
