300
xamWebMap - paths - first path doesn't show up.
Below is about the simplest possible code for drawing a line between two points.  the event is tied to a button that coexists on a page with a xamWebMap.  The map is pretty much drawn from the samples.
The odd thing is that DrawPath_Click does nothing the first time around.  I can see an element added to xamWebMap1.Layers[0].Elements and the visible attribute is set to visible but it doesn't show up on the map.  The second and subsequent calls to DrawPath_Click are fine.
I checked to see if maybe I was one rendering behind all the time and I don't think that's the case but I am often wrong.
private void DrawPath_Click(object sender, RoutedEventArgs e)
drawLine(36 + numCalls, -80, 39 + numCalls, -95);
numCalls += 1;
void drawLine(double srcLat, double srcLong, double destLat, double destLong)
MapPolylineCollection lines = new MapPolylineCollection();
List<Point> points = new List<Point>();
points.Add(new Point(srcLong, srcLat));
points.Add(new Point(destLong, destLat));
lines.Add(xamWebMap1.Projection.ProjectToMap(points));
PathElement lineElement = new PathElement() { Polylines = lines };
lineElement.Fill = new SolidColorBrush(Colors.White);
lineElement.StrokeThickness = 2;
xamWebMap1.Layers[0].Elements.Add(lineElement);
Rect worldRect = lineElement.WorldRect;
worldRect = lines.GetWorldRect();
lineElement.WorldRect = worldRect;
