I was playing with the Avee Sample and I think i may have found a bug?
it seems that the Normal Template as well as the Minimized Template have a mouse over feature. however the firsttime you load up the page (Tiles is normal template) the mouse over feature does not work. when you select a tile and have one Tile maxed and the others minimized the mouse over effect works on the minimized items. when you go back to normal view the mouse over effect works on the Normal templated tiles.
it seems that the mouseover effect should work the first time you load it up. any chance any one knows why this does not work this way??
thanks, love the sample by the way
Is there any downloadable link for Avee sample? My sample were never installed in the location you mentioned.
Rayman
i believed its installed when you instal the package. you can get to it from the start menu.
here is where it is located: C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2009.1\Silverlight\Samples
Where do you get the Avee Sample code?
Thanks for the post,You can correct this in AveePaneStyle by changing "hover" border visibility:<Border x:Name="hover" Visibility="Visible" ...Regards,Marin
