Is there any way I can Hide Area(Maroone Border) showed in the attached\below picture.
Tried following style, Still I am seeing Some space in the the timeline, Is there any way that I can see only the zoombar. Well I have to get Axis Scale and Scale labels on the zoombar. I tried adding a new zoombar control, but Iam not able to see the Axis Scale & Labels. So I am trying to Hide the Entire Scene of Timeline and display only Zoombar.
<Style x:Key="TimelineSceneStyle" TargetType="igTimeline:Scene">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="igTimeline:Scene">
<Grid Background="White" Margin="0,0,0,0">
<igTimeline:GridArea x:Name="GridAreaElement"></igTimeline:GridArea>
<Grid Style="{TemplateBinding SceneGridStyle}">
<Grid.RowDefinitions>
<RowDefinition Height="0" />
<!--set the height to 0-->
</Grid.RowDefinitions>
<igTimeline:SeriesPane x:Name="SeriesPaneTopElement" />
<Grid x:Name="AxisPaneElement" Height="0" Grid.Row="1"></Grid>
<igTimeline:SeriesPane x:Name="SeriesPaneBottomElement" Grid.Row="2" />
</Grid>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
Kola
Kola,
Can you tell me the version number of the timeline you're using, e.g. 9.1.20091.1000 ?
I think we fixed this recently. It should be ok in next version/hotfix.
OK. And I am Trying to do the zoom bar style. When it loading on design getting following error. If I close and run the application, then no issues.
You can just change the Height of the Timeline and hide the legend. Try using:
<igTimeline:XamWebTimeline Height="70" MinHeight="70">
<igTimeline:XamWebTimeline.LegendStyle>
<Style TargetType="igTimeline:Legend">
<Setter Property="Visibility" Value="Collapsed" />
</igTimeline:XamWebTimeline.LegendStyle>
</igTimeline:XamWebTimeline>
