Could you please help me to achive Auto-Scrolling on XamWebTree after dragging a node from one parent to another,.
Samir
Hi Gerenski,
Thanks for your help and support.
But given solution is not 100%.
Is it possible to implement New Drag & Drop Framework with Tree View.
Thanks...
I am sending you a sample for how this could be done, but please also keep in mind that those are only quick solutions to demonstrate one of the options that comes to my mind.
Please, see the attached solution.
HTH,
Hi Stoimen Gerenski,
The above Solution works fine for my requirement. Thanks for your Help.Here we are facing one more problem while Draginng a item to Target Folder.Issue Description:If we drag an item to Target Folder where Target Folder may Contain Another Child Folder which is collapsed at that moment, So in this Case we need to expand the Target Folder on Dragging one item to target Folder so that we can see what are all the Child Folders existed in that target folder to place the Draaged item to child Folder.Simply i want Target folder to get expanded when item is dragged on it.Please advice us for above issue. If possible Please provide Sample Code.Cheers,Samir
Please check the attached solution.
Thanks & Really appreciate your quick response.
I am using silverlight and unable to get GetBounds().
Please help
