Hello Everyone.
I am using master page concept in my application(asp.net). In the content page i have webdialog window and inside wibdialog i have button control with ascyn refresh as below.
<ig:WebDialogWindow ID="digFilter" runat="server" InitialLocation="Centered" Modal="True"Moveable="False" Width="810px">
<ContentPane><Template><table><tr><td>
<igmisc:WebAsyncRefreshPanel runat="server" ID="pnlAsyncfilter"><asp:Button ID="btn" runat="server" Text="Test" /></igmisc:WebAsyncRefreshPanel>
</td></tr></table></Template></ContentPane></ig:WebDialogWindow>
When i click the Test button its posting back to server. But, when i do this same concept without master page its not posting back to server and working fine. Any idea greatly helpful
Regards,M.seenuvasan
M.seenuvasan,
I recommend using UpdatePanel in place of WebAsyncRefreshPanel (WARP) in this scenario. This is because WARP is built atop of our own CallbackManager framework for AJAX, while UpdatePanel and WebDialogWindow are built atop Microsoft's ASP.NET AJAX framework. The two frameworks can't be reliably used together, with an object from one framework inside an object from another.
When you are using a Master Page, you must register the triggers in the Page_Load, like this:
protected void Page_Load(object sender, EventArgs e) { this.WebAsyncRefreshPanel2.AddLinkedRequestTrigger(this.Btn); }
Hope this helps.
