I'm using LoadOnDemand.ManualSmartCallbacks in UltraWebTree to add nodes
dynamically on DemandLoad event.
Everything working fine, but on postback all the nodes getting cleared.
How to retain all those datas on postback ????
WARP panel with manual load helped me. Thanks mate.
ganesh_cbe said:Everything working fine, but on postback all the nodes getting cleared.
The best option is to use the "Manual" load on demand style instead. You can provide AJAX functionality to this setup by placing WebTree inside of a WebAsyncRefreshPanel (WARP) or an UpdatePanel. Once nodes are loaded in this setup, they remain loaded through postbacks.
