70
Dynamic Row Selection
I want to highlight some of the rows of GridView depending on certain condition.
For eg.
If a web grid contains 3 colums Emp id, Emp Name and Salary then I want to highlight those rows with Red color whose salary is greater than some value say 10000.
Can I know how to implement this using web grid?
  • 2301
    Verified Answer
    Hi:
    I think you may find this sample helful as well.
    http://www.componentsforjsf.com/WebGridExamples/faces/examplePages/customBackgroundForCell.jsp
    Best,
    Jim
  • 1765
    Hi drumilbhattad, Row background color could be set in serverside as well. Please follow below steps.
    Thank you!
    Swetha
    1) In JSP: Bind all the <ig:column> 'style' attribute to bean as shown below.
    <ig:gridView
        dataSource="#{webGridRowStyleBean.dataList}"
        id="grid">
          <ig:column style="#{DATA_ROW.basicBg}">
            <f:facet name="header">
                <h:outputText value="First Name" />
            </f:facet>
            <h:outputText value="#{DATA_ROW.firstName}" />
        </ig:column>
    </ig:gridView>
    2) Backing Bean: In getDataList() method check if salary is >=10000 and set ‘background-color’
    private List getDataSource() throws Exception{
                dataSource = new ArrayList();
                PersonInfo personInfo = new PersonInfo("Boyle", "Allene", 8000 , "768-4994");
                dataSource.add(personInfo);
                personInfo = new PersonInfo("Rolfson", "Karine", 12000 , "663-6448");
                personInfo = new PersonInfo("Roberts", "Blaise", 9000 , "037-9519");
                personInfo = new PersonInfo("Okuneva", "Anaya", 15000 , "695-8691");
                personInfo = new PersonInfo("Ken", "Steve", 10000 , "147-2589");
                return dataSource;
          public List getDataList() throws Exception{
                List list = getDataSource();
                Iterator iterate = list.iterator();
                while(iterate.hasNext()){
                      PersonInfo personObj = (PersonInfo) iterate.next();
                      if(personObj.getSalary() >= 10000){
                            personObj.setBasicBg("background-color: red");
                return list;
  • 19693
    Hello ,
    There is one way to do this by using JS function.
    The below one changes the style of every row which contains “a” letter inside the third column
    and selects the row. This function should be called inside the onload method of the body tag and
    pageChanged property of the ig:gridClientEvents. The whole jsp is in the attached file.
    function changeStyle() {
    var elm = document.getElementById("formID:gridID");
    // grid component id
    if (elm != null) {
    var mygrid = ig.grid.getGrid(elm);
    if (!ig.isNull(mygrid)) {
    var gridbody = mygrid.getBody();
    if (!ig.isNull(gridbody)) {
    // get all the the list of rows from the grid
    var rowList = mygrid.getRows();
    // iterate through the rows of the grid
    for (i = 0; i < mygrid.getRowCount(); i++) {
    // get the third cell from the i row
    var cell = gridbody.getCell(i, 2);
    var newCell = new IgGridCell(cell.elm);
    var text = newCell.get_text();
    // check the content of the cell about the desired value
    if (text.match("a")) {
    // iterate through all the columns of the row
    // and change their style
    for (j = 0; j < mygrid.getColCount(); j++) {
    var rowCell = gridbody.getCell(i, j);
    var newRowCell = new IgGridCell(rowCell.elm);
    newRowCell.elm.style.cssText = "color:red; background-color:blue;";
    // get the i row and select it
    var row = rowList[i];
    var newRow = new IgGridRow(row);
    newRow.select();
    Let me know if you need any other assistance.
    Sincerely,
    Tsvtelina
