70
Update Panel and WebTab
Hi
I have a scenario like this
I have a user control in a form  ,inside user control
left side UltrawebTreeView control ,Right side UltrawebTab where each tab contains one user control
When I click a node in treeview control , I basically need to refresh the contents of the Tab control.
So When I does this ,the whole page is getting refreshed.
In order to achieve ajax ,I have kept Update Panel around  treeview and the untraweb tab.
So here the issue is ,
The UltraWebTab inside the Update panel is not working properly.
I am not able to navigate between the tabs because of the update panel.
Can any one suggest me how I can make the WebTab working  even with Update Panel?
  • 24497
    Suggested Answer
    UltraWebTab should work in UpdatePanel same way as any other control. The only exception is the AsyncMode in tab can not be used, because call-back managers of UpdatePanel and tab are not compatible. If that is the case, then similar configuration is not supported. Same restriction is applied to WebAsyncRefreshPanel.
